tartan 22cc
Old 04-15-2013, 10:20 AM
horneydevil
Default tartan 22cc
i have a tartan 22cc engine and cant get my torqmaster to turn the engine fast enough to start it...does anyone a suggestion as what to do??????????
Old 04-15-2013, 03:48 PM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Default RE: tartan 22cc
Do you have a gas version or glow? Usually gas engines are easily hand started, if glow just get it wet and bump start. Either way it shouldn't take much RPM to get it started, you may have a different issue
Old 04-15-2013, 05:26 PM
horneydevil
it is a glow engine and with the plug out it turns over easy then put it back in and it just barley turns over....
Old 04-16-2013, 05:07 AM
darrolair
Use an 18 volt drill battery pack with your starter.
Old 04-16-2013, 05:42 AM
horneydevil
thanks i will give it a try
Old 04-16-2013, 09:04 AM
Gray Beard
My Feedback: (-1)
I went over to the Harbor Freight 18 volt pack last year after John Buckner posted up with the packs number, for $5.00 bucks more you even get a fast charger for it. Now my starter with a fresh charge will even roll over the DLE 30 gasser. 18 volts gave it the kick it needed.
Old 04-16-2013, 09:56 AM
JohnBuckner
JohnBuckner's Avatar
Yup a 1.2 cubic inch and change high compression two stroke twin cylinder is going to be a challange for many starters and a practical solution often is increasing the voltage.
I have experimented with many starters on the market and my favorites are the dynatron's and I love the geared and direct drive pair I have but they are heavy and expensive. Of the lower priced starters (which are actually medium priced) I think the Sullivan and the rebranded Sullivan's such as Pylon and Royal which alway have yellow colored plastics are a much better starter and one that will handle higher voltages (current) a little better.
The 90 Torquemasters which alway use the red colored plastics are a nice clean design just do not have the power of the Sullivans.
When the currents are equal. I have not used a 180 Torquemaster but the several I saw being used did not seem to be impressive.
Pictured is my latest which is the Pylon Brand, a rebranded Sullivan that can use the 18 or 24 volt Black and Decker drill battery and either battery would handle your engine with ease. Also is a pictured of a Torquemaster 90 with the 18 volt B&D on the slider mount. It is not quite up to the Sullivan/Pylon but also would handle your engine. The Torquemasters its my belief that 18 volts is the practical limit for the switchs.
I myself prefer to stay away from Lipo battery simply because of the accidental deep discharge danger with a starter.
John
ID:	1872684   Click image for larger version
ID:	1872685   Click image for larger version
ID:	1872686   Click image for larger version
ID:	1872687   Click image for larger version
ID:	1872688   Click image for larger version
ID:	1872689   Click image for larger version
