O.S 65 LA help
O.S 65 LA help
My brother has a O.s 65 la that is one hard starting S.O,B!! BUT once you plug the muffler she fires right up so what could could be the blame here re did the fuel lines and a new tank same thing you have to plug the hole to get it fired up motor is less then a year old
My Feedback: (9)
GA
RE: O.S 65 LA help
ORIGINAL: Capt. Clarence Oveur
My Feedback: (9)
GA
RE: O.S 65 LA help
Lol that's the "problem", open the throttle all the way, put your finger over the carb or exhaust and flip the prop until you see fuel go into the carb, without the igniter of course , then try to start it. An engine cant run if it doesn't have fuel.
