Reload this Page >
Ar635 rx servos
Ar635 rx servos
Old 06-09-2013, 06:07 PM
Stick 40
Default Ar635 rx servos
I picked up the Ar635 RX and it says it needs , high torque, high speed, high resolution , digital servos
did not know what I was getting into when I bought it, just wanted to look better flying!!!!!
I general use Hitec, but would appreciate any recordation's.
Price is a consecration, but not a show stopper.
sticks
ps I can't find the book, but I think that is what it said it wanted. I will fine the book.
Old 06-10-2013, 05:27 AM
BarracudaHockey
BarracudaHockey's Avatar
Default RE: Ar635 rx servos
What plane? What Hitec servos are you using?
Old 06-10-2013, 03:05 PM
Stick 40
I have a Cap 580 I would like to tame, its about a .90 2 cycle.
I am looking for sevros for the RX
I found the book and it asks for, digital, high speed and high resolution. I think I said high torque on the post and that was wrong.
anyway I general use hited, but am not glued to them. Just would like to stay with the same servo I have been using.
Old 06-11-2013, 05:38 PM
invertmast
My Feedback: (23)
invertmast's Avatar
Get some spektrum A6020's, metal gear, digital, all for $35ish each
Old 06-12-2013, 06:23 AM
Stick 40
wow, thanks.
I did not think I would get by that cheap, do you know if they are high resolution as well. I can go and check, just wondered.
sticks
Old 06-12-2013, 08:58 AM
Gray Beard
My Feedback: (-1)
If you go to a place like servo city on the net you can look up all the different servos and see the specs for yourself. There are too many servos to choose from these days so it's nice to read up on all the different brands and models. There are also close out sales where you can get some great deals.
Old 06-12-2013, 01:03 PM
Stick 40
hi,
went there , too many to look at.
called and he set me up with 4 HS 7966 servos, at 45 ea. Its a bit more than I general pay, but got to have them
thanks
sticks
Old 06-12-2013, 03:13 PM
jbrowne
ORIGINAL: Stick 40
Spektrum specifically states - not for nitro or gas, so I'm not sure that it would be wise to use it with your 2 cycle
  • http://www.horizonhobby.com/wcsstore...ons/bullet.png); background-attachment: scroll; background-color: transparent; line-height: 20px; background-position: 0% 3px; background-repeat: no-repeat no-repeat;">Designed for park flyers, sport planes and 3D airplanes up to 90-size electric airplanes (not designed for nitro or gas aircraft)[*][/list]
Old 06-13-2013, 04:30 PM
Stick 40
I talked to a guy when ordering them, he never asked what kind of plane or engine/motor.
I will get back with them.
thanks for the input, even if I don't like it!!!! LOL
sticks
Old 06-14-2013, 12:54 PM
TomH
TomH's Avatar
I got two 635's the manual makes strong reference on not using nitro/gas. they also say digital, but I put the first one in a proflie foamie (reg. servos) as my test plane and it did fine. digital just has abetter/faster response. the other one is with dig. servos. they work nicely. if you can set it up with all servos set to normal it will make your first setup easier. also you have to use a Y connector for ail.
Old 06-14-2013, 01:05 PM
Stick 40
Ok, guess I did not read the manual very well. went back and reread the manual and your right.
what do you mean by setting the servos to normal? Is that for reg servos or the digital, etc ones?
I guess that changes things, but does not stop forward movement.
I was going to put my ys63 on the funtana S40, but I think it would be a better elect plane anyway. this will work out to be a nice setup.
thanks
sticks
Old 06-15-2013, 04:20 AM
TomH
TomH's Avatar
Normal or reverse, if you can keep them in the normal position, then you can just use the default settings. Not trying to discourage you, but I spent a few hours learning how to set it up. It does make flying fun. Check rc group forum I think there is a whole section on this unit. Check under "radio" .
Old 06-15-2013, 10:09 AM
Stick 40
Ok , I will check the radio forum out.
I was on the edge about the funtana, wanted to go elec and wanted to put the ys in a plane. I guess the ys will wait for another plane.
thanks
sticks
