retracts
Moderator
RE: retracts
that's sort of a broad question, without much info.
what exactly is your criteria for 'right' and 'best' ?
standard/taildragger?
Tricycle w nose wheel steering?
odd/ different geometry? (rotating / 80 degree / multi tire)
what type aircraft will they go in?
I've had GREAT luck with the newer 'servoless' retracts...
RE: retracts
Ditto on the Lado retracts. I don't know if they're the best, but they are certainly very good.
http://www.lado-tech.net/en/
