covering
covering
hi guys
I am in the process of re covering an old bird and having a PITA of a time at it.
So I was looking for the vido'a that Rc.Ken made to see if I can find some tips that will help
I think one of the reasons I am having most of the trouble is I am trying to use up a lot of my old covering material. biggest problem area is going arround compound cures.
So any suggestions will be a help
Thanks in advance
Cheers Bob T
AMA13377
RE: covering
Is this article by minnflyer what you were looking for?
http://www.rcuniverse.com/magazine/a...?article_id=67
videos http://www.rcuniverse.com/magazine/a...article_id=726
Moderator
RE: covering
I helped Mikey (my Brother, Minnflyer) with those articles
Compound curves are ALWAYS a PITA... but as I recall that issue is 'covered' ( :-D ) in the videos.
c'mon back if you're still having issues, as far as 'old' covering, I've never had a big issue with that specifically,
unless it was crappy covering in the first place.
RE: covering
If you're using Monokote or some of the cheaper coverings, curves and wing tips are a challenge. In my opinion, you would probably have better success using Ultracote.
