ARF BUILDING
Old 07-23-2013, 04:00 PM
p3arljam
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default ARF BUILDING
I heard when you are building an ARF its always good to strengthen the joints. What should i use for this (specific brands) any links would be appreciated.
p3arljam is offline
Old 07-23-2013, 04:55 PM
jetmech05
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ARF BUILDING
thin CA will work good
jetmech05 is offline
Old 07-23-2013, 05:35 PM
hookedonrc
hookedonrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I tried to post this, but it would not take...trying again. I usually reinforce the engine firewall with triangle stock wherever necessary. Add reinforcement to landing gear mounting area. Add a Sullivan tail wheel when th stock one puts stress on the rudder. Also reinforce the bulkhead where the wing mounts by doubling it and change out soft wood mounting dowels with oak ones.
And on large planes I swap out CA hinges for dubro pinned ones.
hookedonrc is offline
Old 07-26-2013, 04:49 AM
airbusdrvr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: jetmech05
I use 6 or 30 min epoxy for firewall, landing gear and wing bolt plate. Also triangle stock or similar if there is room.
airbusdrvr is offline
Old 07-26-2013, 04:55 AM
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
LOL
sensei is offline
Old 07-26-2013, 05:55 AM
perreback
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: sensei
LOL
Why?
perreback is offline
Old 07-26-2013, 07:42 AM
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Why???
Simply because there is another forum that I spent months documenting the purchase of a new in box 35% H9 Extra 260, I completely went through the airframe by stripping the new covering off repairing, re-gluing, and lightening. Finally this thread is followed up with full flight video at completion of the project. I was going to share the link because there is a great deal of information about going through an ARF and updating but as I have stated in this forum before, management thinks that there is a good reason to disallow information sharing from one site to another, so they don't allow certain forum names to be used keeping us from sharing a link to other threads that may benefit some. That's why...
Bob
sensei is offline
Old 07-26-2013, 10:24 AM
daveopam
My Feedback: (9)
daveopam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just take med CA and go over what joints I can get too. The landing gear block is weak and many, many , many ARF's but is often hard to get too.
Just be careful about adding weight. I have seen guys add some tri stock here, epoxy there, a touch of plywood on this and that and pretty soon the plane is 16oz heavier. A lot of RC planes see 10-15 G's several times on each flight. 16oz @ 10Gs is 160oz. So while you think you are helping the airframe there are times you are hurting it. Not just performance wise but pretty soon the plane needs reinforced because your reinforcements added too much weight.
david
daveopam is offline
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
