TO COVER OR NOT WITH MONOKOTE, THAT IS THE QUESTION!
My Feedback: (8)
RE: TO COVER OR NOT WITH MONOKOTE, THAT IS THE QUESTION!
I have had good experience with Ultracoat, can't say the same for Monokote. Ultracoat goes on fairly easily with not a ton of heat. A touch with the iron gets a tack, one rub along the edge gets a seam, and sweeping motion with the heat gun gets nice uniform shrinkage.
There are two things I particularly like about Ultracoat:
1) The 'light' version looks great and is super light and easy to work with. It also matches the standard weight fairly well.
2) With wrinkles, I find Ultracoat to be the easiest/quickest/cleanest to re-shrink. I have a tough time with Monokote wrinkles. Other stuff pulls away at the seams.
There was no internet back in those early days, so like others; I leaned to cover from the school of hard knocks. As MonoKote changed I found that I needed to change the way I applied it as well. Here are a couple of pics for view, the red Double Vision Biplane has a covered in Stits and painted fuselage, and covered in MonoKote wings and tail feathers, the checkered 300 has a painted cowling, canopy deck and wheel pants, everything else in MonoKote, and the same goes for the yellow and black 260. By the way as I stated earlier I purchase only the 25' rolls, in the picture that I am covering the yellow turtledeck, that represents a full 6' roll if purchased that way, so you can see why I use the big rolls to cover with, it take around 5 rolls with drop to cover the big ones.[]
Bob
Bob
MA
What I have found with mono is that when trying to shrink it you have to heat it then let it cool then heat it a again. If you just hold the heat gun you will do nothing or burn a hole in it. But if you let it cool and hit it again it will shrink right up.
#33
Oddly enough, just this week I tried some inexpensive covering from Hobbyking (China) on my girlfriend's Dynaflite Butterfly. I must say I'm impressed..... light, good opacity, very pliable around curved surfaces and sticks and shrinks very well. And it's CHEAP.
