Momentary loss of control
FL
Spektrum Dx7s and AR8000 receiver. I will notice a short lived loss of control and then when I land the red light is blinking, not a fast flashing but maybe 1 second on, 2 seconds off or so... The manual troubleshooting says "Receiver slowly blinking at landing" but it does not specify what color light so I don't know if thats what they're talking about or not. Anyone know ?
FL
I had my fuel tank burst so I have everything out of the plane right now. I did notice however that my secondary receiver (the part with two antennas on it) was not mounted where the manual for the plane shows it to be mounted. I thought I had it in the right spot but guess not.
Where I had it was 1 or 2 inches away from the intended spot, not sure if that can even make a difference or not though.
My Feedback: (29)
Usually location is only important on airplanes that are using large amounts of current. You wouldn't want a satellite RX next to some wires that are pulling 3 amps or next to an ignition module. For sport airplanes you would not want it near metal control rods or metal rudder cables. I like to keep the antennas horizontal as to expose them to as much signal pattern as possible. The extensions for the satellites are notorious for connector issues. Check the connectors carefully, I would take new ones and add a little Goop around the connector where the wire intersects. if you don't have one already, get a battery checker that will load the battery. Horizon has them pretty cheap and i know mine has saved at least one airplane.
Moderator
Isn't the red light the "hold" indicator? If that's right, the blinks indicate the number of times the receiver lost the signal during your flight. A move within the plane should fix it if that's the issue.
Watch my videos and you will see why the red light comes on.. the number of times it flashes demonstrates how many times it has lost contact with the TX.
I have personally never had it happen while flying, might be worth checking your RX / Satellite positioning and doing a full range check.
http://www.youtube.com/watch?v=4_Tbes9f1_c http://www.youtube.com/watch?v=ZH-EiOGBb9c
Hmmm I don't use my DX7 any more. I lost 2 planes and almost a third. 3 different receivers and battery packs. Think my Transmitter has an intermittent fault. Bound with another DX7 with my trainer after Imanaged to get it to the ground and didn't have any issues after that.
My 2c worth
My 2c worth
Moderator
My 2c worth
My 2c worth
IMHO Jester_s1 and Rob2160 hit the nail on the head... Check both the receiver and satellite position / antenna including the connector to the satellite.
EDIT: additionally, check the connections between the battery and receiver including the switch for anything loose / intermittent.
My Feedback: (10)
Red LED Hold Indicator
The AR8000 features a red LED that indicates the number of holds that have occurred since
the receiver was last powered on. The LED will flash the number of holds then pause (e.g.,
flash, flash, flash, pause, flash, flash, flash, pause indicates three holds occurred since the
receiver was last turned on). Note that holds are reset to zero when the receiver is turned off.
During the first flights of a new airplane, it’s recommended to check the red LED hold indicator.
If it’s flashing, it’s important to optimize the installation (move or reposition antennas) until no
hold occurs. On later flights, the LED Hold Indicator can be used to confirm RF link performance.
http://www.spektrumrc.com/ProdInfo/F...000-Manual.pdf
CHECK YOU RECEIVER INSTALATION IN THE PLANE. Also look over your transmitter antenna. The signal was not being received. Not a battery issue. I recommend getting longer wires for your satellite receiver- the 3-4 inch wire it comes with is not long enough to get you good separation. Hobby king sells them for about 2 for a 36" extension. Try to get your satellite at least a foot away from the receiver. and clear of metal or wires.
Moderator
+1 my mistake in my earlier post... the symtoms described would NOT be caused by an intermittent battery connection.
