Futaba 14SG, R7008SB and S.Bus
CT
I am trying to setup my R7008SB to use the DG-1 and DG-2 switch channels as I have used 11 of the 12 proportional channels for servos and an ignition switch. I would like to use the two switched channels for navigation and dashboard lights. I thought channel 13 was DG-1 and channel 14 was DG-2, but I do not get any response on either of these channels from the receiver connector 5 or 6 (channel 13 or 14) when the receiver is set to Mode D. I also set the SBD-1 decoder to channel 13 and 14 and do not get a response. How can I get the two switch channels, DG-1 and DG-2 with the R7008SB receiver and S.Bus?
