hinges
hinges
Going to recover my wing and is it necessary to install new aileron hinges or leave alone and place the wing material just forward of the slot where the ailerons hook up . Ailerons do not need recovering so I was thinking on leaving them there and just do the wing and not have to cut the hinge and reinstall. Don't know if I could get the slot clear of old material. gphil
I've done it both ways. One thing to watch for if you leave the existing hinges in is the heat from the covering iron softening the epoxy that holds the hinges in (if you are using pinned hinges). Just don't leave a hot iron near the hinges too long. Never tried it with CyA hinges.
Thanks for all the info and yup have decided to just go to bare bones take off the ailerons and do a good job. It will be my first time covering and everyone needs the experience .Trying to take shortcuts is not an option. yes hate to install the Ca hinges but that is part of this hobby too. Once more, thanks for all the input. gphil
Moderator
If you haven't already removed the ailerons yet, you can just cut slots in your trailing edge covering and push it through. Assuming your have enough aileron travel to be able to get the iron in there, no one will ever be able to tell the difference between that and having taken them off and rehinged. If you have taken them off already, don't try to re-install new CA hinges in the same slots the old ones were in. The strength of the hinges comes from the CA soaking into the wood, and anything that's been glued before with CA is sealed off from any more soaking in. You'll have to move to new wood to install new CA hinges, or either switch to a pinned type hinge and spend ridiculous amounts of time digging that old CA hinge out if moving them is not an option.
Sorry to say , the ailerons have gone under the knife thirty minutes ago. lol Not enough room anyway but sure appreciate the advise. The information given on this forum is priceless. People of this hobby are so ready to help and new people like me really benefit form all. Thanks. gphil
John
