Reload this Page >
Devcon 5min epoxy problem
Old 11-19-2013, 01:19 AM
rvt64
Default Devcon 5min epoxy problem
Hi,
Does anyone know how to dissolve the Devcon 5min epoxy glue? I used it to glue the pivot pants on the aileron and elevator surfaces of my SDS MXS-R but left to much distance between the wing and aileron / stab and elevator. I would like to fix it, but still be able to use the existing pant holes. Any help would be appreciated.
Robert
Old 11-19-2013, 03:54 AM
sensei
sensei's Avatar
Dissolve... Not a chance, just cut them down the middle and place new ones beside the old ones.
Bob
Old 11-19-2013, 12:33 PM
DavidAgar
My Feedback: (108)
DavidAgar's Avatar
I have to agree, it would be extremely difficult to do. As mentioned, cut them loose and start over again. Good Luck, Dave
Old 11-19-2013, 01:54 PM
countilaw
countilaw's Avatar
Dissolve, no way. But you can heat epoxy with a heat gun and try to peel the softened epoxy from the area.
Frank
Old 11-21-2013, 05:29 PM
Gray Beard
My Feedback: (-1)
I use the heat gun whenever I make a mistake, {OK, Once} and then you are able to re-use the part too. If you get a lot of back up heat blast back into the heat gun it will also burn it out. How would I ever know that??
Frank
