Aroma Therapy?
Aroma Therapy?
At times in the past I've encountered very pleasant smells from other's glow powered aircraft. It seems to only come from four stroke engines usually upon start up. I don't know if this is castor oil or some particular brand of fuel I'm smelling but is a very pleasant, cooked rather than burned smell. I'm using a four stroke powered airplane now but don't seem to ever encounter it in my own airplane. Perhaps my nose is desensitized due to using a different fuel, familiarity, or saturation of the senses.
I like glow smells regardless of type, however this is over and above all else - even burnt kerosene, avgas, and 1/2A fuel odors.
I heard one can add cologne/aftershave to a gallon of fuel to achieve a pleasant aroma; have you ever done this? What kind and how much have you added?
Wildcat has an aftershave type smell to it. I often notice it when running up a plane on the ground. I use nothing but Wildcat in my 4 strokes, it is the only one I found that lists oil content on the bottle, the other brands on the shelves don't. Maybe it is the Klotz that I smell. I did see on the shelf at Hobbytown perfumes for glow fueled cars. I gave it a fleeting thought, but then realized, only the birds would be smelling it.
I know I've never used Wildcat fuels before perhaps because I've either overlooked it, was afraid of it, or I use what is available at local hobby shops here in the mid-Atlantic region. Thanks for the advice.
AHHH the smell of coffee and castor glow fuel in the morning. That brings back memories. Good ole K&B 1000 fuel had the best smell to it. Not like the synthetic fuels today. It was sweet and satisfying.
Buzz.
Buzz.
