model airplane restraint
CA
Local hardware stores sell screwdrivers and twine.
Put the good sized screwdriver in the ground.
Create a loop of 1/8" twine that goes around the screwdriver, under the fin and over the top of the fuse.
Tie it in a bow.
When you are ready to taxi, pull one string, pull away and go flying.
Old diving weights instead of a screwdriver will work fine also.
Good Luck,
KW_Counter
Tie it in a bow.
Good Luck,
KW_Counter
My Feedback: (13)
MN
I looked at all of the high priced restraints when I started flying gas planes. I ended up using cotton rope looped over the vertical and horizontal stab on one side. This has never failed and can be carries in the wing bag. Cheap and effective.
Greg
Greg
