Engine angle
Reply
Old 02-05-2014, 07:28 AM
chestervw
My Feedback: (20)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Engine angle
Building a powered glider, ( butterfly ), I want to know what would be the results in the plane's handling if I don't put the engine on the down angle that is shown on the plans and just mount it at 0 degree angle?
Thanks, Chester
chestervw is offline
Old 02-05-2014, 07:46 AM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Under power it will want to climb. The down thrust is there so that the elevator trims the same power off and on.
speedracerntrixie is offline
Old 02-05-2014, 08:13 AM
chestervw
My Feedback: (20)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks , for your help.
Chester
AMA 74894
Moderator
AMA 74894's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yup.
you'll be 'chasing' the elevator trim. when you've got some power on (say half throttle) it'll want to climb gently but persistently.
with full throttle it'll likely want to climb like a homesick angel. at idle it'll fly straight and level
on the other hand, if you trim it to fly level at full throttle, it'll want to dive with a lower throttle setting.
AMA 74894 is offline
