Reload this Page >
ESM - P-51B Mustang - "BaldEagle - Engine Ques. HELP????
Reply
Old 02-08-2014, 01:27 PM
Electriceddie
Electriceddie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default ESM - P-51B Mustang - "BaldEagle - Engine Ques. HELP????
Hi Guys,
I just wanted to get some opinions about using an OS Max 1.20AX engine in the ESM - P-51B Mustang -"Bald Eagle"?
Manufacture Specs:
Wing Span: Approx. 71”
Fuse Length: 62.3”
Wing Area: 6.11sq. ft
Wing Loading: 33 oz/sq. ft
Weight Approx.: 13.5lbs.
Engine: 1.08 2 cycle -1.20-1.50 4-cycle or 26CC gas
Prop Recommendation: (For OS 1.20) 16x8 or 15x10
Would this OS Max 1.20AX engine with a - "J'TEC"-Radiowave In-Cowlmuffler, set up inverted, be a good choice? I don't want it to be marginal inwhere I need to run the engine at 75% to 100%full power just to keep the plane flying.
I really need a recommendation for Prop sizes this particular Warbird / Engine 1.20 OS Max setup? I have checked with OS and OS Max recommends 16X8, 15X10. But I was looking for someone who may have a similar set up and which Prop Size, Brand & Typethat worked well for them.
Thanks Guys
Ed
Electriceddie is offline
