9cc engine
Reply
Old 02-13-2014, 07:36 AM
Papalonjoven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 9cc engine
Will a 9cc engine run properly without the provided fuel pump?? I read that installing a pressure line from the muffler works, on the ground is ok, after I installed a one way valve it seems to have too much pressure, some advise??
Papalonjoven is offline
Old 02-13-2014, 04:32 PM
j.duncker
j.duncker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More info needed on engine eg make and on the installation.
Pics are good.
Your question can not be answered on what you have supplied so far.
j.duncker is offline
Old 02-14-2014, 05:22 AM
Papalonjoven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ngh 9cc, apparently fuel pump;regulator not working properly, if I install fuel line fuel line from pump to carb will start and run actually it runs great, I'm afraid to fly it in that way, I believe it will need some pressure when flying, if I run a line from muffler does great, when I put a one way valve from muffler to tank, toooooo much pressure, so it floods, some advise??
Old 02-14-2014, 10:06 AM
JollyPopper
JollyPopper's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You have two confiturations in which the engine runs "great" and you're looking for something else? I don't understand.
JollyPopper is offline
Old 02-17-2014, 08:34 AM
AMA 74894
Moderator
AMA 74894's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
it should be fine... but we even already have a thread going on for that exact engine...
NGH 9cc
if you'll post your question there you may get more info...
AMA 74894 is offline
