spinner on rcgf gas engine
My Feedback: (69)
Hi, need some help wanting to mount a spinner on a rcgf 20cc engine it has a 8 x 1.25 bolt thru the middle to hold prop on i want to mount a aluminum spinner if possible any idea would help. Thanks charles
Try one of these companies.
http://www.dbproducts.com/store/vortulti.htm
http://www.truturn.com/product_line.html
My Feedback: (158)
specifically you'd want this
http://www3.towerhobbies.com/cgi-bin...?&I=LXHMF3&P=C
the same size CB nut here (scroll way down)
https://mecoa.biz/shopdisplayproducts.asp?id=82
I use the CB nut on my dle 20,, works great,,, you do want to double nut if possible,,, good luck
