Biplane Cabane Question
Reply
Old 02-26-2014, 08:09 AM
RCdude13
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Biplane Cabane Question
I need a method to mount 3/16" music wire cabanes to the upper wing which has 10-24 T-nuts built into them. I was thinking of welding a fender washer to the end of each wire. On smaller bipes I have used elecrical wire copper terminals saudered to the wire, however, the upper wing is 90" so I need something much stronger this time. Any suggestions?
RCdude13 is offline
Old 02-26-2014, 10:05 AM
R8893
My Feedback: (20)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
We have a group build of 7 1/4 scale Camels underway. We used the first clamp under galvanized on our cabanes. Soldered to cabane wire.
http://www.mcmaster.com/#catalog/120/1535/=qv41w4
Chuck
R8893 is online now
Old 02-27-2014, 06:42 AM
jester_s1
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Have you thought of using landing gear straps? Of course, that would require installing two more T nuts.
jester_s1 is online now
Old 02-27-2014, 10:13 AM
RCdude13
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I drilled a 3/16" hole in a large fender washer. I'm going to weld it to the end of the cabane wire. I drilled the hole at the same angle as the cabane so it pretty much sits horizontal on its' own. Thanks for the ideas guys. How about this one...how do you neatly hide the servo wires and the terminals at the top of the cabanes?
RCdude13 is offline
Old 02-27-2014, 01:49 PM
CafeenMan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One way to do it is put a separate receiver and battery in the upper wing.
CafeenMan is offline
