servo glitching on my Sundancer
Reply
Old 03-10-2014, 04:48 AM
katman74
My Feedback: (23)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default servo glitching on my Sundancer
Hi Everyone, Hope someone has some insight on my problem. Flying my Sig sundancer, yesterday( 50cc DL and futaba 2.4) when the throttle started breif acceleration spurts on and off in the air.
Plane was flying fine besides that. So I figured I better land and did so. When I taxied back to the pits and while the plane was sitting at idle I noticed the left elevator went up and down by itself. Note ignition
was replaced about a month ago. Were should I start looking.
katman74 is offline
Old 03-10-2014, 08:44 AM
michael wood
michael wood's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
use a hose clamp on the spark plug cap. happened to me and that fixed my problem
michael wood is offline
Old 03-10-2014, 08:59 AM
katman74
My Feedback: (23)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Michael,
Does it go on the cap and plug together. Am I having an interferance problem
katman74 is offline
Old 03-10-2014, 10:08 AM
AMA 74894
Moderator
AMA 74894's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
it definitely sounds like the ignition circuit is causing interference with the radio. did you do a range check?
why was the ign replaced?
is the ign module, it's battery and all it's associated wiring all located and routed completely away from all wiring for the radio?
(like all forward of the firewall?)
is the radio's airborne battery fully charged?
I have heard of cases where not having the spark plug wire fully seated (or simply loose) can cause interference issues, but I have not witnessed them personally.
(this is what Michael is referring to, you'd add a hose clamp clamping the spark plug wire's rubber boot to the spark plug itself)
AMA 74894 is offline
Old 03-10-2014, 12:00 PM
katman74
My Feedback: (23)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jim
ignition was replaced because the old one went out. It's a DL 50. Ignition itself, with wires and battery for ignition are located behind firewall. Receiver and servos start under wind saddle(about 10'') from ignition. Good point
on the main battery pack. I better check it again. None of this happened during the first flight. Range check was good on first flight.
Keith
katman74 is offline
Old 03-10-2014, 12:52 PM
AMA 74894
Moderator
AMA 74894's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok.. I was JUST making sure it wasn't replaced because the old one was 'causing interference'
it sounds like your installation is good, (at least no glaring 'no-no's...)
DO make sure though that the ign plug is FULLY seated on the spark plug...
good luck! let us know what you figure out.
