JR transmitter
Reply
Old 03-12-2014, 08:45 AM
mecanic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Unhappy JR transmitter
Finished building my plane, had been using the radio the entire time to set up the controls on the plane. I finished and charged all batt. Turned on the Jr radio and nothing, no led, no movement of any kind, checked with another known good batt. still nothing. Checked fuse, ok, power to board but that was it. This totally sucked as I had all JR servos and reciever, already mounted.Anyone have any ideas?
mecanic is offline
Old 03-12-2014, 08:57 AM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would say check the fuse again. I have had the same thing happen a couple times.
speedracerntrixie is offline
Old 03-12-2014, 09:33 AM
AMA 74894
Moderator
AMA 74894's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yup! I did that too.... checked the Fuse SO WELL (with a continuity tester) and managed to not get it seated properly back in the tx...
I'd double check the fuse, and check for voltage on both sides of the fuse if you can.
AMA 74894 is offline
Old 03-12-2014, 03:05 PM
JohnBuckner
JohnBuckner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Go one step further, Replace the fuse
John
JohnBuckner is offline
Old 03-12-2014, 06:09 PM
52larry52
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had a "senior moment" last month and plugged one of my JR transmitters into a Futaba charger! I popped that fuse and had no spares and no LHS within 40 miles (as if they would have one anyway). My local Radio Shack came to my rescue with suitable replacements. The bad news is two weeks ago when Radio Shack announced it was closing many of it's stores, my local Radio Shack was on the to be closed list.
52larry52 is offline
Old 03-13-2014, 07:27 AM
jetmech05
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fuses can look good and be bad.... Replace the fuse or check the fuse with a multimeter
jetmech05 is offline
Old 03-13-2014, 07:46 AM
OldScaleGuy
OldScaleGuy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Also confirm you have the polarities correct on the servos, battery pack and switch.
OldScaleGuy is offline
Old 03-13-2014, 10:20 AM
Luft-Gangster
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Had a JR radio about 10 years ago. All others were Futaba. Not thinking, I plugged the JR into the Futaba charger. Herd a pop sound and nothing worked. JR's are reverse polarity to other radios. Took it in to Pete Waters for repair. It blew a diod because of the reverse polarity. Safety feature to protect the radio for this reason. Cost about $25 for the repair.
Luft-Gangster is offline
