Glow driver?
Reply
Old 04-14-2014, 07:40 PM
fly dat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Glow driver?
I quit using the standard clip on glow drivers and started using a clip on one with the banana plugs plugged into a power panel. I had a lot of trouble keeping the other ones clipped onto my inverted engines.now I'm tired of lugging my field box around. I really like the rcats but that's more then I want to spend. I was wondering if a mini power panel with either a small lipo or life battery connected to it would work? Is there any good drivers with the wired plug and small battery out there?
fly dat is offline
Old 04-15-2014, 05:42 AM
jester_s1
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If your portable glow driver wasn't staying on, the ends of the prongs that hold it on were probably worn straight. I have to take a pair of needle nose pliers to mine every 6 months or so because of that.
jester_s1 is offline
Old 04-15-2014, 08:24 AM
JollyPopper
JollyPopper's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I MUCH prefer the glow drivers that turn and lock onto the plug over the sliding sleeve kind. The sliding sleeve versions work fine on upright installations, but crosswise or inverted, they keep falling off,.
JollyPopper is offline
Old 04-15-2014, 07:14 PM
jester_s1
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have the sleeve kind, but I agree the twist lock kind stay on better. I use the sleeve ones in sideways and inverted setups though. They do require the tweaking that I mentioned above. Right after an adjustment, they stay on very well.
Old 04-16-2014, 05:17 PM
JohnBuckner
JohnBuckner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Fly Dat, I pretty much agree with the fellows and much prefer a twist lock type over the sleeve type connector So for the majority of my sport flying I just prefer the twist lock type on a single cell ignitor.
Using a power panel is something I will not use and even consider them dangerous, even worse when corded starter is used in conjunction with a corded ignitor.
Both the twist lock and the sleeve type connectors if abused can cause problems, The problems with the twist lock happens when the fellow get excited and forget to push down before twisting.
There is a third type as you can see in the photo and it is an ignitor alligator clip. Certainly not the alligator clips we used as kids but an intended for the purpose alligator clip. I think min came from Derrol Cady (you can google that name for info as he is a pylon specific supplier) I think maybe Radio South also had them.
The portable glow driver in the picture came from Radio South and is an older model of what they have now but work the same. This one uses four Nicd cells and uses electronics to instantly adjust the current demands of you glow plug. This helps to burn out a flooded plug.
John
Name:	Glow ignitors (1).JPG
ID:	1987587   Click image for larger version
Name:	Glow ignitors (2).JPG
ID:	1987588   Click image for larger version
Name:	Glow ignitors.JPG
JohnBuckner is offline
Old 04-17-2014, 08:34 AM
JollyPopper
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have one like the Hot Shot 2 that John shows in his third picture. It is my favorite glow starter. I have four or five sleeve types that I don't care much for. The only problem I see is that the battery in that twist and lock glow starter is attached somehow to the working end of the thing and I am not sure how yet. So what happens when the battery quits taking a charge? A new one, I guess. They are cheap enough.
Old 04-17-2014, 10:53 AM
JohnBuckner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes Jp The hot shots are cheap enough to simply replace when the time comes but they last a surprisingly long time and mine are in almost daily use, normally keeping two charged all the times
The type that have an aluminum housing that unscrews for a loose sub C cell are great in theory however of three or four of those that I have used all have proven rather unreliable and none have served as well as the Hots shot, I think because the cell in the Hot Shot is essentially not replaceable (or not worth the effort) is the reason for its superior reliability. The threads of the aluminum case seems to be a constant source of problem and have to be constantly cleaned to allow current to flow.
John
Name:	glow drivers 2 (1).JPG
Old 04-23-2014, 05:33 AM
JL1
My Feedback: (93)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The rcats driver is a fine unit, I have been using one for the last three years with complete satisfaction. Btw, I have no commercial connection, I am just a very satisfied user.
JL1 is offline
Old 04-23-2014, 08:48 AM
landeck
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
+1, five years here.
Bruce
landeck is offline
