balancer setup
Reply
Old 04-25-2014, 01:21 PM
tazzzz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default balancer setup
Its my luck today.....I was given a dubro prop balancer// the black one with the 2 towers,,, No problem balancing small props,,,,,but cant figure out how to set it up for the larger props, I looked on line and it says it has an over/under option for larger props....cant for the life of me figure it out
anybody know,,,,TAZZZZ
tazzzz is offline
Old 04-25-2014, 04:31 PM
JohnBuckner
JohnBuckner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[QUOTE=tazzzz;,,,
But cant figure out how to set it up for the larger props, I looked on line and it says it has an over/under option for larger props....cant for the life of me figure it out
anybody know,,,,TAZZZZ[/QUOTE]
The two towers are moved to their closest position to one side of the base and the tower on the end has the slider in the lowest position. The other tower has the slider at the highest position so the long cone rod rest level on the top of the wheels on the outside tower but it rides on the underside of the wheels inside that access hole of the tower in the middle.
The long portion of the extra long cone rod now can mount a larger prop in the normal way between the cones extending over a table and it can rotate 360.
John
JohnBuckner is offline
