Best way to glue wings together without making a mess of the covering
Hello,
I've been in the hobby a while, but have never mastered the art of gluing 2 wing halves together without making a mess of the covering around the glue joint.
Regardless of how many times, you trial fit the parts, when you apply the glue it sudenly becomes a high pressure environment to get everything lined up without having to worry about making a mess
Any advise would be appreciated.
Zappulmo
Zappulmo
Moderator
+1 for Jetmech05.
you can also run masking tape around the wing on both sides of the joint so any excess epoxy runs into the tape and not the covering.
(of course, the simplest answer is to glue the wing halves together before covering the wing ) obviously that won't work on a pre covered (arf) wing.
My Feedback: (185)
WA
I drill several small holes in the ribs that are to be glued together. The glue then squeezes into the holes instead of out between the wings, and it also allows for a tighter fit.
AZ
All of the above suggestions are excellent. In the end if you are unhappy with the appearance of the joint, cover it with the appropriate color of 3M plastic tape.
http://www.target.com/p/3m-scotch-as...t/-/A-13805465
I use Epo Grip Epoxy . It is much slower curing .(about 4 - 6 hrs. ) plus it stays where you put it . It doesn't run like regular epoxy . It is more like putty . If you use a rubber glove and wet your finger you can smooth the joint just like glass . The nice thing is you are never rushed , you have lots of time to get everything set the way you want it . Its very easy to work with . I hardly ever use regular epoxy anymore ..
My Feedback: (8)
I would use either tape (masking or clear tape, depending on what's going on), or I might use a good synthetic grease. I use a lot of teflon grease during my last build, it works like a charm. You can coat wing tubes and aligning pins in grease before you glue things together and they seem to always come out just fine.
