Covering Aileron Stock
Reply
Old 06-16-2014, 08:48 AM
RC_Fanatic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Covering Aileron Stock
I've looked at a bunch of covering videos but none seem to cover this issue. I had to replace the elevator on my T-34 when a broken hinge caused a broken elevator. I replaced it with aileron stock but ran into problems trying to cover it with Ultra-Cote. (Okay, I'm a klutz when it comes to covering!) To complicate the issue, the leading edge of the aileron stock is notched at the hinge locations so the barrel of the pin-type hinges can be recessed to reduce the gap.
Rather than amuse you with my approach to this, I'll ask "How should I have done it?" Pictures and/or a video would be great. I'd like to move from ARF-ing to building but covering is my biggest concern.
RC_Fanatic is offline
Old 06-16-2014, 09:25 AM
JohnBuckner
JohnBuckner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would and do just cover the aileron stock completely one side at a time bottom to top before installing hinges regardless of type, then just cutting any hinge recess.
John
JohnBuckner is offline
Old 06-16-2014, 09:45 AM
RC_Fanatic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
John
But when you cut the notches to clear the barrel of the hinges, there will be bare balsa showing. Since the plane has an engine that spews oil and exhaust goop, the bare balsa will soon be a mess!
Old 06-16-2014, 11:34 AM
skylark-flier
skylark-flier's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's where you add a bit of CA glue to re-seal the wood.
skylark-flier is offline
Old 06-16-2014, 11:38 AM
raptureboy
raptureboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just coat the area with a little thinned epoxy or CA before hinging. I prefer to use a tapered dremel bit to open up the hole with rather than notching so that the hinge recesses in. I cover the hole thing then use the heated tip of a soldering iron to melt the hole open.
raptureboy is offline
Old 06-16-2014, 12:05 PM
RC_Fanatic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks. I think that will work best.
