nitro fuel tank install
Reply
Old 07-04-2014, 09:12 AM
feep
feep's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default nitro fuel tank install
IO am refurbishing a Sig Senior Kadet and The fuel tank is tucked up inside the fuselage right behind the firewall inside a bracket that is pretty tight fitting. The tank is 16 oz and I will leave it as is but I'm wondering about vibration and foam inside. I am trying to avoid opening the fuselage . Any thoughts?
feep is offline
Old 07-04-2014, 01:12 PM
jetmech05
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How old is the tank and the lines?
jetmech05 is offline
Old 07-04-2014, 05:33 PM
feep
feep's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the tank must have come with the plane but I was able to remove it and clean it out and replace the lines. As I said it goes back in, but it's a tight fit leaving no way to put any insulation around it so it rests directly on a bulkhead.
feep is offline
Old 07-04-2014, 06:31 PM
JohnBuckner
JohnBuckner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Foaming is not what it once was and most modern fuels include antifoaming agents Give it a go
John
JohnBuckner is offline
Old 07-04-2014, 08:19 PM
Charlie P.
Charlie P.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lots of glow models for engines without fuel pumps are designed to have the tank snug to the firewall. I cut a tank neck size hole in a piece of 3" x 3" foam rubber and push the tank right up snug against the firewall (with a hole drilled to accomidate the tank neck and plug).
Charlie P. is offline
Old 07-05-2014, 04:07 AM
jetmech05
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You'll be ok I'd fly it
Old 07-05-2014, 04:48 AM
feep
feep's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks guys i never considered antifoaming agents. I've been flying gas engines for the last 10 years.
feep is offline
