Crank case venting
IA
Crank case venting
Hi all I've got a Saito150 and I'am contemplating plumbing the crank case vent line into the lower end of the exhaust, that way the exhaust would carry any blow by away. My concern is would I be creating pressure on the vent thus not allowing the motor to vent..... thanx Max
While I have no valid data to substantiate this, I'd recommend that you do not do this. Now, some of the engines do route this vent back to the intake venture but I've never been a fan of that either as any combustion particles that get into the crankcase due to blow-by or down the push rod tubes could cause excess wear on the piston/sleeve area. Note; this is only my thoughts with not a lot of data to substantiate it.
When it's convenient you can sometimes run the crankcase vent tube into a slightly larger short length of aluminium tubing and use that to support the line and run it clear of the airframe.
