dle 20 voltage
Reply
Old 08-05-2014, 04:22 AM
Stick 40
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default dle 20 voltage
I just picked up a plane with a dle 20 and the battery's are old, or at least not known to me.
I went to tower hobby's and got the manual and it says the engine system can take 4.8 to 6 volts. He had a 4 cell 4.8 V battery in it.
I wanted to put one of mine A123's in it, but wondered if that would be too high a voltage.
sticks
Stick 40 is offline
Old 08-06-2014, 09:22 AM
600Bob
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If we were talking about servos I would say it would be fine. But I err on the side of caution with ignitions. I use one of these for my ignitions with LiFe batteries.
http://www.valleyviewrc.com/estore/r...-bec-6-6v.html
600Bob is offline
Old 08-07-2014, 04:50 PM
Stick 40
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yes its for an ignitions system, all my servos are newer ones and I use A123 two cell for the RX.
I will stay with 4.8 V for the ignitions sys. until I know better.
sticks
Stick 40 is offline
Old 08-07-2014, 07:32 PM
jester_s1
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There are numerous anecdotes of ignitions not working right on 6v nicd packs even when the manufacturer says they are ok with them. Then you go down to 4.8v, and they work fine.
jester_s1 is offline
Old 08-09-2014, 02:51 AM
scale only 4 me
My Feedback: (158)
scale only 4 me's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
+1 on the BEC,,
I run dual battery and a BEC on all my gassers now
I use these http://www.tech-aero.net/ultra-ibec
good luck
scale only 4 me is offline
Old 08-09-2014, 04:29 AM
JohnBuckner
JohnBuckner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On my OS 15GT, 33GT and 55cc engines I have formerly used four cell Nimh on all of them but currently all have been changed to six cell Nimh(6volt). This is not because there was a problem but only in the interest of compatability with what I keep in my personal stock all the time.
I do have a DLE 20 but it is still in the box and I am not sure what I may decide to use but probably the six cell agine. what I would not do and perhaps its just me ( yes my speculation) but I would not use any battery system or battery chemistry that exceeded the nominal maximum listed voltage. Also agine just me but I would not use any added complication of a battery chemistry that exceeded the nominal voltage and required the use of a voltage regulator. To me that is undesired complication.
For my stuff, the battery spark ignition gassers simplicity is my goal and that means two separate independent battery systems, one for ignition and one for flight control and using the same chemistry, voltage if not the same capacity. This very much simplifies charging considerations
John
JohnBuckner is offline
Old 08-11-2014, 05:58 PM
Stick 40
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The 4 cell 2000 is still good, I will stay with that for the engine.
at least until I find out better.
sticks
Stick 40 is offline
Old 08-11-2014, 06:32 PM
JohnBuckner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sounds like a plan
