aileron problem
Have you tried a third aileron servo of the same brand, they are the same brand and model aren't they? Often times in a y the bad servo only acts up when paired with another servo
My Feedback: (-1)
The OP does have another post and just says his ailerons are acting like flaps, if he is using a standard Y-harness there is nothing strange about that. Scrap the Y and with futaba just use the radio and channel 1&6 for flaperons or 1&7 for aileron diff. Either or. He can also buy a reversing Y or move one of the control rods the other side of one of the servo arms. In any case reading the instructions for the radio again would be a big plus.
I'll try to explain it... but it will be really tough to understand... but .... here goes.... if you do something different.. something different might happen..or it might not. That should fix it.. and that works with many things... too many to list. I'm sure you've got it under control now.
