On board glow
My Feedback: (28)
On board glow
I have gotten ahold of a McDaniels duel on board glow setup, my question, does this unit use a separate battery to run glow plugs or does it work off of the planes battery
Thanks Bob
Thanks Bob
Hi Bob Yes its a matter of safety and it not a great idea to power up a system where there is a possibility of excessive dumping of your flight control battery. I have only one airplane with a on board system and the reason is I use this ship for repetitive landing go around's, practicing arrested landings. My setup is the Sullivan and not the Mcdaniels though.
John
John
My Feedback: (28)
John
John
Thanks Bob
OK , I cannot vouch for any details of the McDaniels system and mine is the Sullivan. Actually both those batteries are the same 6 volt packs (five cell) and are independent one one for the receiver and one for the glow driver.
Now what I suspect is your system is probably similar to mine in many ways and is designed to provide the 1.5 volts from a 4.8 volts pack. If that is what the website said the your system I would bet requires 4.8 volt imput in order to provide the 1.5 v output at the plug. That is only my speculation but is the way my Sullivan system works but with 6 volt batteries.
John
John
My Feedback: (28)
You are correct John. I removed the 1.5 and installed a 4.8 battery and know I have a reading. The Molex plug for the glow plug drive only has three pins, 2 black and one red, I would assume that means a ground for each engine and you spilt the red
My Feedback: (7)
Are you putting this on a two cylinder engine or trying to use it on two separate single cylinder engines? I have used these in the past on two cylinder engines the red lead is connected to the crankcase and the black leads connect to the glow plugs. If you are wanting to drive two single cylinder engines you might run into problems with wire lengths causing voltage drop.
My Feedback: (28)
Bob
My Feedback: (28)
Bob
