Pathching Pin Holes in Cowls
CA
Hi,
I have a couple of very small dings in a cowl I'm about ready to paint.
What do people use for these small blemishes?
When I was playing around in auto body class they had a product for that very purpose.
Per the instructor, it was basically very thick paint.
Can't remember what it was called.
Any suggestions would be helpful.
KW_Counter
KW_Counter
My Feedback: (29)
For small voids I usually mix up some 5 minute epoxy with some micro balloons or cabosil. This only gives you enough time to do a couple at a time. For pin holes prior to spraying primer I rub the whole part with light weight spackle. When the spackle is dry sand lightly with 220 just enough to get back to smooth fiberglass. The spacle will remain in the pin holes. After primer, any remaining pin holes can be filled with auto spot putty.
KW-Counter, The product you were trying to remember is called "spot putty" and yes it was just thick lacquer paint. It has no structural value at all and the previously suggested Bondo body filler would be much better suited for a small hole repair on a model airplane cowl. Go with the Bondo body filler to fill the hole, sand and prime, then to fill any very small imperfections left after sanding and priming the cowl, this is where spot putty can be properly used. A light coat of spot putty, sand and reprime, scuff sand the primer, clean it (tack rag), and now paint with the finish paint color.
There is also a product call Glazing Putty. It required a hardener (activator). It is very creamy and very easy to sand. It comes in a small tub and will go a long way. A little dab will do it !! You can get it at any Auto Body supply. It does not shrink and you can paint over it. However, it's always best to use some type of primer whenever you paint.
Frank
Frank
I like to scuff the entire surface first with 180 or 220 grit sandpaper followed by spraying a light coat of high build euro prime, I then fill pin holes and/or blemishes with a polyester two part glazing putty followed with a complete 180 grit sanding until nearly all the primer is transparent and imperfections filled, I then spray a good wet coat of the high build euro prime and block sand the entire surface again with 180 grit pulling off nearly all the prime but truing the surface. Finally I spray a light dust coat of the high build euro prime and sand with 320 to 400 grit prior to my first base coat application.
Bob
Bob
