How to lengthen aileron
My Feedback: (35)
WA
Now that I have extended my wing by about 4 inches each side , I need to extend the ailerons on each side by same amount rather than build new ailerons .
Besides gluing the short piece of extension aileron to the original , is adding a piece of ply or CF bridging the main aileron and the additional aileron good enough ? I will inset the bridge piece so i'ts flush with the aileron surface for looks. There will be one CA hinge in the extension aileron since its slightly less than 4 inches long.
Any other simple way?
My first airplane was a kit.....my new puppy got the end of my aileron. I cut off the damage, cut a length from aileron stock drilled a hole for a tooth pick dowel and glued it together. Worked great.
My Feedback: (35)
WA
I need to find a simple way because the aileron ends 1/2 inch inside of the wing tip. So I need to slide and glue the extension aileron into place and engaging the CA hinge at the same time. Perhaps a simple scarf joint is easiest. 3-1 is pretty long scarf joint.
