Looking for a spinner
I have the Hangar 9 P40B Warhawk 50. I am looking for the 2 blade 86mm nylon spinner. Anyone have a spare for this ARF or have another one in another color like red or black? I can't seem to find them anywhere unless they are carbon fiber. I don't want to pay those prices. I would even think a 3.5" (89mm) would work too. I doubt 3mm will make any difference. At least not to me. Thanks.
sideoftheroad Might I suggest that since most P-40s use inverted engines and that combined with plastic spinners very often end up with those nasty black rings Perhaps its time to step up to an aluminum spinner. If you must use plastic then definitely the color to use is black as this tends to hide the rings.
TLH's link above shows some aluminum types (I also would avoid the carbon fibre types) and here is a link to the Dave Brown Vortech spinners:
https://www.dbproducts.com/store/
John
John
Great Planes offers a 3 1/4" spinner with an aluminum back plate and a nylon cone in white, red, black, or yellow. They are available thru Tower Hobbies @ about $15.00. That's the largest "plastic" type spinner that I know of. Larger than that, you will need to go to the more pricey aluminum type. "If you wanta dance, you got to pay the fiddler".
My Feedback: (158)
[TABLE="width: 100%"]
[TR]
[TD="width: 29%"][/TD]
[TD="width: 8%"]3 1/2"
P40[/TD]
[TD="width: 9%"][/TD]
[TD="width: 10%"]
[TD="width: 8%"]
[TD="width: 8%"]
[TD="width: 28%"]Spinner Cone
Aluminum Back Plate
Shaft Bushing Set
8-32 x 2 1/4" Attachment Screw
1/4" x 28 or 5/16" x 24 Adaptor Nut
Other sizes available at
additional cost.
[/TD]
[/TR]
[/TABLE]
[TR]
P40[/TD]
[TD="width: 10%"]
Complete
AssemblyCB 5085
CB 5087
CB 5089
[/TD]AssemblyCB 5085
CB 5087
CB 5089
[TD="width: 8%"]
Replacement
Cone
CB 5086
CB 5088
CB 5090
[/TD]Cone
CB 5086
CB 5088
CB 5090
[TD="width: 8%"]
Color
RED
BLACK
WHITE
[/TD]RED
BLACK
WHITE
Aluminum Back Plate
Shaft Bushing Set
additional cost.
[/TD]
[/TR]
[/TABLE]
[TABLE="width: 800"]
[TR="bgcolor: #0099FF"]
[TD="bgcolor: #00CCFF"]
[TR]
[TD="width: 60, bgcolor: #00CCFF"][/TD]
[TD="width: 402, bgcolor: #00CCFF"]
3.5 RED P-40 SPINNER
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD="width: 150, bgcolor: #00CCFF"][TABLE="align: center"]
[TR]
[TD][TABLE="align: center"]
[TR]
[TD="colspan: 2, align: center"]Price: $21.95[/TD]
[/TR]
[TR]
[TD="colspan: 2, align: center"]Qty: [/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
Part Number: CB5085
Old Part Number:
Stock Status: GOOD
[TABLE="width: 476, align: center"]Old Part Number:
Stock Status: GOOD
[TR]
Adapter Nut
1/4 x 28 Adapter Nut
5/16 x 24 Adapter Nut
NO adapter nut discount - ($1.00)
Other Size Adapter Nut - Request size at check out in special instructions. + $2.00
[/TR]
[/TABLE]
[/TD]
[TR]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
Flycatch. I had 2 objectives in my post. One was in hopes that someone else had or has the Hangar 9 P40B Warhawk 50 ARF that might have bought a couple extra 86mm spinners that was made for this plane and might be willing to part with one. The plane is long out of production and they cannot be found anywhere. Part 2 was if part 1 wasn't possible to see if anyone had resources for a spinner of similar size that I hadn't already looked at. After all I did state I am only finding carbon fiber for that size which I didn't want to pay those prices and I'm looking for nylon. Even if I hadn't done the research, sometimes it's much easier to reask the question over and over and over again vs spending hours digging through a bunch of info looking for a needle in a haystack. I've already gone through the hangar 9, horizon hobby, dubro, hobby king, ebay and other sites to name a few before posting this. I didn't know mecoa had spinners and have no idea who Dave Brown is so I didnt know that site even existed. I usually say what is on my mind so quite frankly responses like that just turn people off to the hobby altogether. I am a couple years young in this hobby so my questions will seem basic and anytime I can get help is always much appreciated. Now that I've received help next time when someone else needs help with a similar question I can pay it forward with the information I've learned. As stated before isn't that the idea behind the site, is to help each other out?
Hey sideoftheroad you needed to make no explanation to that rude responder in post #8 who had nothing to contribute and apparently seldom does other than contempt for this website.
I do hope I contributed also and by the way The Great planes plastic with the alum backplate that 52Larry mentioned and the CB alum backplate plastics that Scaleonly linked are much preferable over the all plastic types. This is because there is less of the problem of the backplate deforming during tightening and there is groved capture ring in the alum backplates.
John
John
John. Yes you have helped. I wasn't sure what you meant by the black rings though. Also correct me if I'm wrong but the CB spinner, aluminum spinner or any for that matter that you have a screw at the end of the cone, is that just for gas engines or can that be for nitro too? I wouldn't think it would matter but I'd rather ask than not know.
My Feedback: (158)
Hey sideoftheroad Yes the single center screw through the cone to an adapter thats screwed onto the end of the crankshaft is the best type of spinner. Sometime long,medium and short adapters are avalible to suit your components and yes this method has been used since the begineings of Nitro engines.
My apologies on the black ring thing. The black rings are endemic on plastic spinners and very difficult to avoid especialy when an inverted engine mount is used. It is caused when a starter is applied to an inverted engine that may not be properly cleared, as the result is the ugly burned in black ring. And I was serious if you go plastic do choose black so this will not be so noticible.
John
John
Sideoftheroad, Looks like by group action you have several choices to resolve your problem. If I were you I would go for the 3.5" red P-40 spinner from MECOA as suggested by scale only for me. A lot of p-40's had red spinners. I also didn't know MECOA sold spinners, so we all are learning from your question. BTY the black rings that John referred to are score marks that can occur when your electric starter cone slips on the plastic section of the spinner. If the spinner is all aluminum the score marks don't happen. Careful use of the electric starter (and a good rubber insert) will minimize the black ring problem. And lastly, the spinners with a single center bolt are fine for glo engines.
I've looked at the Mecoa site from time to time at engines and parts. I HAD NO CLUE the CB spinners were still available from them. I've been modeling off and on since "75". I think of Mecoa as an engine vendor only. Time to change that attitude
Ken
I have used a number of them in the past and they have some advantages first and formost is the capture ring type back plate and the plastic is thicker than that from some others. One down side is usually depending on your prop size normally some custom grinding will be necessary in most sizes. And of course sooner or later most folks are going to burn a ring regardless off the starter insert especially if the airplane is an inverted installation.
John
John
John
John
