Saito 100 Muffler Extension
My Feedback: (15)
NJ
Does any one know if Saito makes a manifold extension? I need to add about 1.5 inches to my current manifold so I can get the muffler to exit the cowl on this plane I'm building. A 90 degree adapter does not help my cause. I see SAI65143 which is a 6.5 flex extension, but that is too long and I would prefer something rigid. Any ideas? Thanks for reading.
My Feedback: (15)
NJ
You did not read my post carefully. That is what I have now and need to ADD another 1.5 inches so the muffler will be outside my cowl. Horizon sells a 6.5 inch flexible exhaust with nuts on each end. I may go that route, but that part is over $40. I was looking for a cheaper solution but there appears to be none.
