looking for pictures and ideas for taking planes to and from field
1 Post
Wingbags dramatically reduce 'hanger rash' I make mine from bubble wrap and extra wide duct tape. Fuz bags with velcro closures are also easy to make.
Creating a high 'shelf' for the wings is a good idea. Eyes and bungee cords worked for me. You must have a close front to prevent the wings coming forward in heavy braking. I used some mesh from a kids playpen.
I have always had an estate car and would travel with wheels in recesses in a block of styrofoam. and the noses up against the folded forward seat. Worthwhile having a sacrificial carpet to catch the drips if you fly IC or jets.
My Feedback: (90)
Here is how I did the racks in my 2004 Chrysler Town & Country. It's built with 1" PVC. Just behind the "jog" on either side, the back side of the tee connector has no glue, so it can be separated and removed, or just the front or rear section can be removed as needed. Plenty of room underneath for smaller models, flight boxes, etc.
My Feedback: (10)
I built a similar PVC rack in the back of my Truck, I used 1" PVC, but inside the long pipe sections, I placed wood dowel the entire length of the pipe sections, the dowel was longer than the length of the pipe so it would extend into any PVC joints, not sure what diameter dowel I used, but a diameter that would insert inside of the inner diameter of the pipe, maybe 5/8" or 3/4, what ever fit worked well, it made the whole structure a little stiffer and added support.
I went with something similar to the pvc but in wood. Two simple racks, fuselages on bottom, wings on top, bungee tie-downs. Chevy Uplander minivan.
Handles 4 planes.
Handles 4 planes.
1 Post
Having an obstructed view to rear can get a traffic ticket in some US states. Not a problem in the UK when I was there providing you had side mirrors. You might want to check your state laws before building a high rack.
My US built RV had a rear view TV camera which was the DBs.
My Feedback: (-1)
I don't take apart my Bipes but I keep the spans 68 inches and under. A 68 inch Boeing and a 66 inch Tiger Moth and the van had enough room for all my flight gear and camping equipment, Just took a bit of planning to get it all in. I usually only take three [planes to the field and just lay the fuse in the back and use the front seats to keep the wings from falling over or shifting.
I just throw them in, and drive carefully. Keep the toolbox separate, they slide and do damage. Ask me how I know. I put egg crates under the wheels so the planes don't roll. I think a fishing net on the ceiling is good for wings. I used a table for wings, and it tipped over and ruined 4 planes. Typical day of flying here, oops, forgot the wings... Not really, moving them to the new house. Probably two more trips minimum.
My Feedback: (90)
Here is the same rack system that i have in my '04, set up in my '94. In these pics, I'm all loaded for a trip to Bomber Field in 2013.
[ATTACH]2104927[/IMG][ATTACH]2104928[/IMG][ATTACH]2104929[/IMG]
Dont know why the pics did not set a preview. Click the links to open. Gotta love RCU
I have a full size GMC Suburban, I made a 1/4" 4 X 8' ply floor nailed to 2 X 2s so it is removable. Racks made of PVC pipe works well for up to 60 size planes, mine is removable for 2 1/4 scale planes. Mine isn't finished yet but there are several posted good examples to give you some good ideas. These things can be made two tiered also.
One pict has a start stand on it for up to 60 size planes, I have bad knees.
LG
LG
A friend built this for his trailer, you could easily make one for your van.
Rolls in on wheels & has 2 retractable legs to support it when it pulls out.
I have to make new arrangements to accommodate a new model in my trailer, I'll be
building one of these for sure. Once removed it provides a storage rack for your models.
John.
John.
