Reload this Page >
Airplane keeps turning left f27 Stryker c slightly
Old 09-29-2015, 05:40 PM
dartvader
Default Airplane keeps turning left f27 Stryker c slightly
I've had this plane for awhile and for some reason I can't seem too stop it from keep turning left on me when the control stick is natural very slightly it's been crashed a couple of times any one can help thanks 😄😄😄
Old 09-30-2015, 06:52 AM
rt3232
Having said it has been crashed, do you know all of the surfaces are straight and with out warp's.
Check the engine/motor alignment for left thrust.
You also did not say if it is rolling left or yahing left, turning can be started by eather.
Cheers
Old 09-30-2015, 07:16 AM
kmeyers
kmeyers's Avatar
Do you know how to trim an airplane?
Old 09-30-2015, 11:11 AM
dartvader
Pretty sure it's not that I think maybe the left wing might be causing the issue I could post pictures if yah want
Old 09-30-2015, 04:25 PM
rt3232
It would help, !
Do you have an incidence meter if so just take a reading at the rout (next to the fus) and then at the tip that will tell you if that side is straight do the same on the other side Note the plane just needs to be in a level flight position. you can do the same thing by just marking spot on the leading and trialing edge's and measure with a good scale
Cheers
Hope this helps
Old 10-03-2015, 08:17 PM
jester_s1
Moderator
Is the plane yawing or rolling? I have many flights on my F27C. I can tell you that if you didn't reinforce the fuselage it will eventually warp from flight stresses. That can cause some wing twist which will put you out of trim.
