Vintage 97" Fairchild 22, What size engine required for this airplane?
This will be a vintage 97" Fairchild 22 restoration. The airplane is a high wing open cockpit two seater. What size gas or 4 stroke engine will be required ?
Looking for suggestions.
The plane weight without engine and fuel is 6lbs.
Wingspan is 97", Wing cord is 17"
Fuselage is 66" long
JimB
JimB
My Feedback: (68)
I've got the same Orline kit,from what I read over the last few years,I'd put a Saito 150/180,or a G38.Add some extra structure in the wing,guys were folding there wing.I was thinking about sheeting the spar to leading edge,and cap stripping.(open wing construction).good luck-jeffo
The Orline Fairchild that I'm familiar with had a G-38 for power.
