Enya 60X / 7101
Enya 60X / 7101
Hello All,
Not sure if this is the right forum category but...
I've acquired an Enya .60X, model 7101, which has an odd looking pump mounted to the backplate. I have no idea how old this is- it’s obviously been run a fair amount and the included Pitts muffler seems to have come from a larger engine as the original mounting holes are plugged with what looks like JB weld and new holes were drilled to mount it to this engine. Does anyone have any familiarity with this engine? I can’t find much of anything on line. In particular I’m trying to identify the low idle screw before attempting to start it, as if I fiddle with the air bleed by mistake I may have a hard time getting it right. There's no idle screw on the end of the throttle arm as I'm used to seeing on OS, Saito etc.
Any help, links to info etc. are appreciated!
