removing 30 min epoxy
Whats the best way to remove epoxied in plastic hinges from control services. I jumped ahead one step, and need to remove the rudder hinges to start over again
thanks TAZZZZ.
thanks TAZZZZ.
The trouble will be when you reglue. The wood will already have glue soaked into it, you really should use new slots. So with that in mind cut the hinges and then cut new slots. Or better yet leave the hinges if possible and work around your issue
I think ill rehinge cause I have to get the rudder off to insert the tail wheel wire, its one of those sig kadet sport taildragger models, I jumped the gun,thought I would set the hinges. (I was bored) then read thru the instructions. I was going by my sig kadet senior nose wheel model. (I let the horses out first,,,then opened the door. (darn).
thanks guys TAZZZZ
thanks guys TAZZZZ
Id like to install a Sullivan tailwheel but unfortunetly the bottom of the rudder is completely covered by the stabilizer. Does anyone have a way to install one? Its a Sig kadet senior. Has anyone done this on this particular model. Ive thought about but cant seem find a way to do it. Any pics would be highly appreciated.
Thx a bunch
TAZZZZ
Thx a bunch
TAZZZZ
