Purpose of Side Port on AR636 Receiver?
Reply
Old 03-20-2016, 04:40 AM
lasdoug2011
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Purpose of Side Port on AR636 Receiver?
I cannot find any literature on the purpose of the Side Port on the AR636 Receiver. I'am assuming it is for a Remote Antenna. Can anybody help me?
lasdoug2011 is offline
Old 03-20-2016, 11:57 AM
BarracudaHockey
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you're talking about the white port shown here, yes, its for a remote receiver
BarracudaHockey is online now
Old 03-21-2016, 02:12 AM
lasdoug2011
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank You Very Much. You would think the opereating manual for this receiver would at least mention this Port!
Old 03-21-2016, 04:37 AM
BarracudaHockey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
While we are at it then, here's another tidbit that isn't in the manual.
If you decide to add a remote receiver make sure it matches the protocol of the main receiver. I'm pretty sure that's a DSMX receiver (it will be marked) so make sure if you add one you get a DSMX remote to match.
Old 03-21-2016, 10:03 AM
lasdoug2011
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank You Again Barracuda - Yes it is a DSMX Receiver, didnt know if TELEMTRY might also be plugged in that slot too. Lack of info in the Receiver Manual is unbelievable! By the way, at age 14 in florida on a deep sea fishing boat I caught a 33" Barracuda, we had it stuffed and the Razor Sharp teeth still remains a vivid memory!
Old 03-21-2016, 11:10 AM
BarracudaHockey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Awesome!
Telemetry is built in to that receiver, using a TM1000 telemetry unit would plug into the bind/data port (I forget if that rx has a data port)
The only thing that side port is used for is a remote.
Old 03-21-2016, 11:38 AM
lasdoug2011
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just looked at the AR636 receiver , The BIND port is labeled (BIND/PRG), and I was interested in Telemetry for Battery Voltage, but did not like that you had to splice into the battery wires to make that Voltage Telemetry connection. Isnt there a T-connector type plug that allows you to connect the Battery and the Voltage Telemetry through a T-connector of some sort. Do you by anychance know of a easier way then splicing?
Old 05-02-2018, 08:09 AM
rtbates
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use the balance connector.
Yes, the Ar636 has a dedicated data port out the other side from the remote antenna port.
rtbates is offline
Old 05-02-2018, 04:11 PM
tailskid
My Feedback: (34)
tailskid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That is SO TRUE and is a well kept secret and 'may' explain some the problems that have plagued the line....thanks for reminding us of this!
Jerry
tailskid is offline
Old 05-08-2018, 03:44 PM
DGrant
DGrant's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jerry
One more old secret for an old thread. When adding a new or additional remote receiver to any Spektrum system, the system needs to be re-bound with the new remote receiver installed, so it recognizes it. That part isn't in any manual either that I know of. I often wonder how many remote receivers out there were just plugged in and never bound to the system... thereby just sitting there. You have to look for the red light on the remote rec.. if it's on you're good.. if there's no light on ... it's not bound.
DGrant is offline
Old 05-08-2018, 03:58 PM
tailskid
My Feedback: (34)
tailskid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Another reason to maybe explain so many "brownouts"
Thanks for sharing!
tailskid is offline
Old 05-09-2018, 03:52 AM
BarracudaHockey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The so called brown out is usually from inadequate power supply to the receiver for the application but he's right, add a remote and you have to rebind, after all its an independent receiver so it has to be bound to be functional.
Old 01-09-2019, 12:05 PM
noahb
My Feedback: (67)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have one of these rxs. If i wanted main pack voltage 6s lipo is there a way to interface that with this rx? My rx voltage is present, but would like the pack voltage as well. Any ideas?
noahb is offline
