Bi-plane CG
Normally right side up. You want the vertical CG (i.e., the bulk of the weight) of the plane to be below the wing that place your balancer on. If the wing stagger is large enough, and the design is such, that the CG falls behind the upper wing then you probably have to balance upside down using the bottom wing. A Beech Staggerwing may be just the opposite.
