Life battery
As for single battery I have hundreds of flights with this configuration in a number of gas planes and other than my own lack of skill I don't have any power/battery/radio related mishaps. Also keep in mind, I fly a lot more than the casual modeler and deal with a lot more new airframe installations per year than most, usually 2 or 3 new models a month with at least one of them being a large gasser.
I use 1 2500mah life with a optical kill switch inline to the ignition and the other lead goes to the receiver with separate switches so I can turn on the radio without also making the ignition hot . I have heard that if your ignition would short using just 1 battery that is would kill the battery pretty quickly and that would result in more than a dead stick. I run all my 20cc birds this way without any issues, but then I also rode around without the benefit of seat belts as a kid.You can also use the 2 leads to run parallel switches and then if a switch fails you would still have power to the receiver.
It largely depends on what I'm working with and who's products I'm reviewing and the size.
For say a 50cc aerobatic plane like my Corvus, it has a single 2500mah A123 into a Spektrum receiver with a Tech Aero IBEC powering the ignition. If its a warbird and I need the weight up front, I'd go with a power safe receiver and 2 packs and an IBEC
However I have 30cc stuff with a single A123 pack with dual leads, one goes to a heavy duty switch then to the receiver, and the other lead to a switch and to the ignition.
My 33% Pawnee is setup with 2 A123's in a power safe receiver, one powers the receiver, the other powers the receiver with one lead and the ignition with the other.
But I've heard that when you get abducted by aliens they show you their base in the shadow of Mars.
I've been to the alien base behind Mars as many times as I've had a gas ignition "short out" and drain an ignition pack.
No offense taken. But I would consider Steve Anthoney an expert in the subject of batteries. From his Q&A section on LiFe batteries. www.hangtimes.com "I won't use one and I don't recommend them. One of the more common failures on larger gas powered models is ignition modules.. when the module shorts out from vibration and heat the ignition battery pack goes dead a few moments later.. leaving the pilot with an engine out 'dead stick' landing. With an ignition battery eliminator, if the module shorts, more often than not the pilot is left without power for the Rx too. That's not a dead stick landing. That's a dead aircraft arrival, not a recoverable situation.In all commercial RPV's, military drones, etc, the telemetry system has its own power supply, as does the engine ignition system and the crafts Rx/Servo system. Separation and redundancy.. in larger models, much preferred over combining systems on one pac"
He and I would have to agree to disagree. I've seen poorly mounted ignitions fail, I've seen well mounted ignitions fail. I've never ever seen or participated helping someone where an ignition shorted and took out the battery. Just my personal experience but I've been doing this a long time.
What do you guys think about the new RCExl Optical switch version 2 that has a built-in BEC? You would use one battery to the receiver and the control signal from the receiver to the optical switch also provides the power to the ignition. I am not sure what the failure mode of the version 2 kill switch. If the electronics module happens to short out (however unlikely), does the BEC limit the current draw from the receiver?
Moderator
There needs to be some kind of isolation of the ignition circuit to prevent interference. That being the case, a single battery setup doesn't do much for you. You'll need a BEC and a larger capacity flight battery and with some ignitions a voltage regulator, so there is little to no cost savings. You can save a little bit of weight, but some of that will be taken up by the aforementioned requirements. What you lose is safety from ignition failures and the ability to locate the two batteries in the best locations to get your CG right. For my money, the dual battery setup is simpler and more resistant to trouble.
MI
a Life battery should have a power out and a bal. connector, so are you saying there are three on the pack?
sticks
For high draw setups, some batteries have double switch connections for redundant switches and to supply the high current if demanded. JR has a radio switch that uses the Dean's connector and has two plugs to the receiver; kind of cool. Regular size planes only need one connection.
MI
I looked at the site and the pic. I don't know the connectors shown but they look like power and could be used for
RX and engine.
The white is a Balance port and use it when you charge and use a charger for that battery.
As you were told it would be better to use two on the plane , if you can.
If your engine draws the one down, you can still dead stick.
I like my planes and use two when I can !
RX and engine.
