receiver and ignition sharing same battery
Reply
Old 07-31-2016, 05:06 AM
BarracudaHockey
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got to thinking about this and part of it is about context.
I have warbirds with dual batteries. Not because I feel another battery is needed but because it needs nose weight and I'd rather carry battery weight that's doing something useful than a pound of lead.
On my 3D style birds I would rather save the weight and enjoy the simplicity.
But to circle back to the original question, if properly installed it is NOT an interference problem.
BarracudaHockey is offline
Old 07-31-2016, 06:15 AM
Gizmo-RCU
My Feedback: (27)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I will take my chances, a dead engine (dead-stick) is much better than a dead receiver..............and no interference problem. No doubt the single battery system works for most folks I just feel better with two in my gassers!
Gizmo-RCU is offline
Old 07-31-2016, 10:19 AM
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by BarracudaHockey View Post
IBEC's aside, I have many hundreds of flights on planes with two leads coming out of the battery, one going to the ignition, one going to the receiver, it's not a problem.
Yup, I also have several hundred flights on my 40% Carden 260 I built in late 2006. I bought a DX-7 for guidance, and installed 2 ea. AR-7000 receivers, all fed from 2 Fromeco 2600 ma lions into a wolverine switch that Fromeco setup for me that has 2 ea. input and 3 ea. output, 1 to each receiver and 1 to the ignition module of my DA-100. That was nearly a decade ago, and guess what, no issued to date. The truth is 2.4 is just too far away for RF noise coming off the module to be an issue, or at least that is my own experience. Anyway these days I run a single powersafe receiver with duel lipo 2s batteries for power, I also run the Tech Aero IBEC, this technology just makes good sense...
Bob
sensei is offline
Old 07-31-2016, 07:30 PM
All Day Dan
All Day Dan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK slo, who do you think knows more about the transmission and reception of electromagnetic waves? The electrical engineers at the manufacturer who designed your radio and whose lively hood depends on it success or somebody typing on a keyboard who you have no idea what their qualifications are to even discuss the subject? Dan.
All Day Dan is offline
Old 08-01-2016, 03:33 AM
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ignorance is truly bliss...
Happy Flying,
Bob
sensei is offline
Old 08-01-2016, 06:12 AM
  #31
Murphey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I will be the first to admit that I know absolutely nothing about electromagnetic transmissions, how they work, why they work or what goes on inside those black boxes...an absolute mystery to me. How ever I DO know that a dual use battery system and a Tech-Aero IBEC works for ME. As previously mentioned, one of the great things about this hobby is the freedom to use what ever method or system that makes you comfortable...can't think of too many things worse than flying a plane worrying if something will fail...so if you want multiple batteries...go for it...nothing wrong with that...or the person that chooses one method or the other.
M
Murphey is offline
Old 08-01-2016, 06:55 AM
  #32
BarracudaHockey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well I happen to know at least two of the participants in this discussion have a combined probably 50 years of working on full scale avionics under our belts.
Old 04-15-2019, 04:01 PM
  #33
crobara
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello anyone still out there regarding this issue? When you run one battery do you use an empty slot on the receiver to provide the power to the ignition module?
crobara is offline
Old 04-16-2019, 04:10 AM
  #34
BarracudaHockey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, using a device like a Tech Aero IBEC it plugs into an open channel, you assign a switch and it not only powers the ignition but it acts as a transmitter activated kill swtich
Old 04-17-2019, 10:31 AM
  #35
crobara
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks cudda.
crobara is offline
Old 04-30-2019, 06:41 PM
  #36
onyta
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Only 8 channels
Can I plug the IBEC into a "Y" connector and feed it from say the rudder port ????????
onyta is offline
Old 05-01-2019, 03:13 AM
  #37
BarracudaHockey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No
It needs an aux channel end points otherwise you crank your rudder over and the motor shuts down.
Old 05-01-2019, 09:40 AM
  #38
the Wasp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
it's not a problem until it becomes a problem
Jim
the Wasp is offline
Old 05-02-2019, 11:11 AM
  #39
onyta
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks from Onytay, going another way & stay with 2 bats.
onyta is offline
Old 05-03-2019, 09:20 AM
  #40
scale only 4 me
My Feedback: (158)
scale only 4 me's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jim
That applies to every component in the airplane
Running sepe
scale only 4 me is offline
Old 05-11-2019, 03:46 PM
  #41
kenh3497
kenh3497's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Consider this..... For those of us that remember telephones that hung on the wall..... They were powered by a bank of batteries running at 48 volts DC. The RING was AC voltage imposed OVER the DC voltage to ring the bell. So in my humble opinion it is possible for interference to invade our DC powered systems. Maybe I'm just stirring the pot for no reason???????
Ken
kenh3497 is offline
Old 05-13-2019, 03:36 PM
  #42
scale only 4 me
My Feedback: (158)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well,, like has be said,, many of us have been dong it with no reported issues,,, can you find a report of it ever being a problem?,, sure anything can happen,, and when it starts happening I think there would be a fire storm on the internet about it,, I do't even see any smoke yet,,
I'm no here to convince anyone to set their plane up a way they are not comfortable with,, do what you feel is best for you,,, just telling you what has worked for me
