Reload this Page >
Bec with led lights
Bec with led lights
Old 08-22-2016, 01:51 PM
rabidbat96
Default Bec with led lights
Is it really necessary to use a bec with a turnigy receiver activated led switch with one battery?This would be used for lights only,nothing else.You should'nt need to use a bec,unless you want to eliminate the weight of another battery,if you use the right size should'not matter anyway,unless you are really concerned about weight and flight time.
