Lateral balanceing
Lateral balanceing
I am finishing up a pheonix 540 edge and im not sure how to do the lateral balance. The makers of the arf model offset the engine mount to the right quite a bit. So the engine is no longet on the center line of the fuselodge. When i lateral balance the model do i still use a string around the front of the engine or do i find the center of the fuselodge in back of the motor and balance from there?
Moderator
The balancing you do now is only useful to get it in the ballpark. The real test is flying. On a calm day, do 3 loops using nothing but elevator. You'll see pretty easily if your rudder is truly trimmed right and how good your lateral balance is.
As Jester said, static balancing is just to get started. The true balancing is tested in the air.
Another method of testing for lateral balance in flight is after getting your CG to feel right, trim for long straight passes with no aileron input. Then make long straight passes while inverted. If it drops a wing, that side is heavy. So if it rolls right, the left side is heavier (it was inverted). Stick a chip of lead to the right wing tip and test again. It doesn't take much, just a very small chip at a time.
Dave
Dave
