Klass Kote clear question
Reply
Old 02-15-2017, 07:13 PM
balsabuff
My Feedback: (30)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Klass Kote clear question
In the past, I used Hobby Poxy and K&B clear epoxy paint as an overcoat. In time they yellowed over white surface and looked awful.
Does anyone know if Klass Kote clear epoxy stays clear ? Any suggestions for a non-yellowing fuel proof paint ? Thx. much. 'buff
balsabuff is offline
Old 02-16-2017, 03:06 AM
TomCrump
TomCrump's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Automotive clears, with the addition of a hardener, shouldn't yellow. Do not use aerosols, though. I'm not sure that they are fuel resistant.
TomCrump is offline
Old 02-16-2017, 05:30 AM
RCFlyerDan
My Feedback: (47)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I wouldn't use Klass Kote anymore. I have used K&B, Hobby Poxy, and Klass kote. They are a heavy epoxy paint that nothing evaporates.. I use PPG Omni paints and clear from PPG. Easier to use.
RCFlyerDan is offline
Old 02-16-2017, 05:50 AM
Top_Gunn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Are they OK to use with glow fuel? And can you use the clear over latex?
Top_Gunn is online now
Old 02-16-2017, 06:21 AM
RCFlyerDan
My Feedback: (47)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No on the latex. Not sure about glow. Did you do a search for your answers? There are pages of forums on here for Klass Kote!!
http://www.rcuniverse.com/forum/sear...archid=5395988
Old 02-16-2017, 07:31 AM
Top_Gunn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My questions were about PPG. A search turned up nothing. Klass Kote, which I've used a lot, works fine over latex.
Edit: Well that was the RCU search. A google search worked much better (including RCU results which the RCU search didn't find). Should have known better.
Old 02-16-2017, 08:38 AM
balsabuff
My Feedback: (30)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm going to consider the PPG, since I have heard several good reports in the past about it non-yellowing. I assume that flattening powder works with the PPG. ( am I right ?). I know the PPG clear coat works great for beautiful gloss, since I've painted a couple Ford Mustangs with it, years ago. It's just that I use Klass Kote for models, and wonder if the clear would screw things up. I'm a dyed-in-the-wool old epoxy paint guy, when it comes to model airplanes with glow engines. So if anyone has clear coated their models with the Klass Kote I would sure like to know how it turned out---yellowing wise. Thx. much. 'buff
Old 02-16-2017, 12:41 PM
TomCrump
TomCrump's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think that all epoxies will yellow over time, Auto paints don't seem to have that problem.
I would not spray them over latex, though. I think that may end in disaster.
TomCrump is offline
Old 02-16-2017, 01:11 PM
edp
edp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Balsabuff,
I have sprayed KK clear gloss on my last two pattern birds. Yes, it does slightly yellow. It looks worse in my basement under the florescent lighting than in direct sunlight. I have several flights on the XLT w/o any problems. The Illusion will fly this spring.
[ATTACH]2201531[/IMG][ATTACH]2201532[/IMG][ATTACH]2201533[/IMG]
ID:	2201524   Click image for larger version
ID:	2201525   Click image for larger version
ID:	2201526   Click image for larger version
ID:	2201527   Click image for larger version
ID:	2201528   Click image for larger version
ID:	2201529   Click image for larger version
ID:	2201530   Click image for larger version
ID:	2201532   Click image for larger version
edp is offline
Old 02-17-2017, 04:51 AM
RCFlyerDan
My Feedback: (47)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I did answer you on PPG Omni-
Old 02-17-2017, 07:05 AM
moparbarn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Automotive 2 part/catalyzed clears are fuel proof. I race nitro boats with 65% nitro fuels, no problems with ppg, omni or any others. You can also get it in a spray can, check out y2k clear.
moparbarn is offline
Contact Us Archive Advertising Cookie Policy
