Pull pull for rudder
Yep.... get that fishing line off there... That kev-cord is what I've used on a few planes. I've had it on a 50cc plane for years, and it hasn't budged. I also use it for flying wire rigging. For the crimps, I use aluminum tube cut down to about 3/8" length, then electricians pliers to do the crimp. I only crimp it enough to clamp the cord within tube tightly... as the crimping pliers can easily crimp right through the whole assembly... with practice you can crimp with regular pliers... but the electrician crimp pliers work best. Here's a few examples of crimps made from alum.tube.
