Sullivan Pushrod connector advice
Reply
Old 08-26-2017, 12:03 AM
alarconpiperj3
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Sullivan Pushrod connector advice
Im planning to install the sullivan heavy duty steel pushrod connector on the flexible throttle cable of my piper cub .60 airplane.
The instruccion says: use drop of glue to mantain adjustment. (0-80 nut)
What Kind of glue i should use?
How tight shold the nut has to be to be secure?
If you have another recommendation i Will really appreciate it.
ID:	2229454   Click image for larger version
ID:	2229455   Click image for larger version
alarconpiperj3 is offline
Old 08-26-2017, 01:07 AM
RBACONS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I generally avoid those types of conectors like the plangue as they can loosen up and slip. If your throttle cable is the twisted steel or brass type, I solder on a Sullivan Brass Coupler and screw on some type of clevis. However, a drop of thin CA will work just fine to help secure the bolt on an EZ connector.
RBACONS is offline
Old 08-26-2017, 10:30 AM
jaka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi!
Agree with RBACONS! A better way and lighter is to use Sullivans thinnest throttle wire in a yellow plastic tubing and solder 2mm threaded end to each end .
jaka is offline
Old 08-26-2017, 12:24 PM
alarconpiperj3
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the advice.
For the moment look like these, but im going to order the brass coupler and the clevis.
Hopefully i Will make the First flight next saturday.
ID:	2229500   Click image for larger version
Old 08-26-2017, 12:32 PM
F4 Phantom blue angles
F4 Phantom blue angles's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can't you just solder it?
F4 Phantom blue angles is offline
Old 08-27-2017, 05:04 AM
jester_s1
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A dab of solder on the pushrod cable where the EZ connector will hold it helps. It keeps the cable from fraying from the pressure and gives the screw a soft but firm surface to bite into. I agree with others that a soldered on threaded adapter is the better way to go, but the adjustability of those EZ connectors is nice to have.
jester_s1 is offline
Old 08-27-2017, 07:41 AM
Pylonracr
Pylonracr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use EZ connectors on the throttle for the ease of adjusting. I will not use them anywhere else. I usually use the small braided cable and solder the last 1/4" or so of the cable so it doesn't fray when I tighten the set screw.
Scott
Edit
I guess I should have read Jesters post a little more closely before I posted, since he said the same thing.........................
Pylonracr is offline
Old 08-27-2017, 07:29 PM
jester_s1
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's nice to have verification that more than one person recommends doing something.
Old 08-28-2017, 03:34 AM
TomCrump
TomCrump's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I do the same as Pylonracer. Like him, I don't use those connectors anywhere else.
TomCrump is offline
