Proper fuel tank set up for 4 stroker
Hello everyone! Been out of the hobby for around 23 years. Just finished up an AcE Clipped Wing Taylorcraft that I started building 23 years ago.
heres my question. Putting an OS 120 FS in it and need to make sure I plum the tank correctly. Thanks in advance for your help!
No difference in tank set up between a 2 stroke and 4 stroke engine (unless its a YS). A 2-line set up is fine if the line to the carb is easily accessible (i.e., not cowled in). One line for the carb, connected to the line in the tank with the clunk on it. A second line for the muffler pressure tap, connected to the line in the tank which terminates at the top of the tank. If the carb line is not accessible, a third line could be run to a fuel dot mounted on the side of the cowl or fuselage.
You'll like your Clipped Wing T-craft !
It'll be Cub-like, with the 1.20 four stroke, ie, diving into loops, etc.
She'll fly well, but I ended up swapping my 1.20 out for a larger 4 stroke.
