Covering balsa clad foam wings
Reply
Old 08-31-2017, 04:05 PM
tkametz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Covering balsa clad foam wings
This is the first time I have covered a foam wing with 1/16" balsa. Is there any danger of melting the foam under the balsa when covering it with Monokote?
Tom
tkametz is offline
Old 08-31-2017, 11:50 PM
ho2zoo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've never had any trouble. If you touch the iron directly to the foam it might melt, but with balsa sheeting it will be fine.
ho2zoo is offline
Old 09-01-2017, 06:31 AM
scale only 4 me
My Feedback: (158)
scale only 4 me's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah,, not an issue,, you'd have to practically burn through the balsa before the foam would be affected
scale only 4 me is offline
Old 09-01-2017, 08:15 AM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would be more concerned about the adhisive used to sheet the wings especially if it were a contact cement type. Even then an issue would be rare. Your covering application technique will play a big part as well. For sheeted foam surfaces I end up using a heat gun for 80% of the work.
speedracerntrixie is offline
