bvm fill valve for retracts
Reply
Old 09-21-2017, 12:32 PM
WhiteRook
My Feedback: (38)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default bvm fill valve for retracts
what is the correct air pump for this ?, the BVM fill chuck ,
thanks RCU
WhiteRook is offline
Old 09-22-2017, 04:09 AM
RCFlyerDan
My Feedback: (51)
RCFlyerDan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can also just use a 3mm tubing(retract tubing) in the center hole to fill it with no other connections. Just don't insert too deep for the flapper valve inside. That is all I use. Works well. Be careful to not get any sand or other dirt inside the valve. Won't hold air anymore if you do.
RCFlyerDan is offline
Old 09-22-2017, 03:52 PM
WhiteRook
My Feedback: (38)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
can you use the robart air pump? or is there any other a pump you can use?
Old 09-22-2017, 04:13 PM
RCFlyerDan
My Feedback: (51)
RCFlyerDan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, or any air pump that pumps a 100psi +.
I am currently using this pump from Harbor Freight.
http://www.harborfreight.com/12v-100...sor-69284.html
I used this one for 7+ years. It didn't quit, I just liked the looks of the other one and bought it. Now this one is my spare in the trailer, incase I forget my other one. On the BVM fill valves, you can just use the air hose attachment as you would a bike tire or car tire. Just have to make sure the valve is extended high enough.
http://www.harborfreight.com/12V-150...ator-4077.html
Here is my installation of the valves in my jet. Notice they are nearly flush with the panel. I use a hose in the center hole to fill the tank. If the hose leaks, like Robart hose won't work to fill in the center, but BVM or 3mm hose will fit snug.
ID:	2233158Click image for larger version
Old 09-24-2017, 05:56 AM
WhiteRook
My Feedback: (38)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ive got a black and decker air station, and I think I can put a basket ball or football air filler inside the bvm chuck
and fill that way, I think the gasket inside the chuck will stop the air from leaking back out.
going to try that
